Broken axle shaft / transmission problem
Greg Becker
05-14-2006 13:10:35
Thanks to all replys on the transmission thread, Its a broken axle shaft I can't belive that big axle shaft let go! Any ideas where to find one?And are the TO,Te and Tea shafts all the same? I live in Michigan.
Bill - SC
05-15-2006 06:35:21
 Re: Broken axle shaft / transmission problem in reply to Greg Becker, 05-14-2006 13:10:35
Greg,
Try Nolt's Equipment, Newville, PA
717-776-6242. Folks on the forum have recommeded them.
John (UK)
05-15-2006 05:04:17
Early TE20 Series are the same, TO30 isn"t. Late type TE20 isn"t. You need axle-shaft with 16 splines, later ones have 19 splines. If you are looking at an axle housing and you want to know if axle-shaft is the same, look around the bottom of the flange where it is bolted to the Centre axle housing, the studs are equally spaced all around, the later one has more studs at the bottom that the top.
