TO35 Hydraulics
Mike in Eastex
05-14-2006 12:36:54
I need to replace a badly rusted lift plunger and clevis, but the only replacement I can find refers to the 35, FE35, and "all w/open center hydraulics". Question is, does that apply to an early TO35 (1955)? I know diddly about hydraulics, and Google and the manual aren"t giving me the answer this time.
John (UK)
05-15-2006 05:25:03
 Re: TO35 Hydraulics in reply to Mike in Eastex, 05-14-2006 12:36:54
The 35 series (FE35/TO35) are all the same for what you are trying to do. Sparex do a Plunger part S03350 equal to MF part 182580M1 and fits TO35 from serial 16554 (1955), they also do the clevis part S41365 equal to MF part 180972M1 and that fits all models of TO35/FE35/F40. If you need Sparex parts you have to order through your local tractor dealer. You can also buy the clevis from this site too.
Mike in Eastex
05-15-2006 06:06:14
 Re: TO35 Hydraulics in reply to John (UK), 05-15-2006 05:25:03
Thanks, John, but when I said early, I meant early early, as in SN:140963. This would have been one of the first of that year. I love having an early serial, but it doesn"t help the spare parts situation a bit. The question now becomes, what is the diference between the plungers? If the S03350 plunger fits the S41365 clevis, and the clevis fits all TO35s, then maybe I don"t have a problem. If the plunger is a bit too long, or too wide at the foot, I can machine it to fit. Problem solved? Or am I missing something important?
John (UK)
05-15-2006 10:30:30
 Re: TO35 Hydraulics in reply to Mike in Eastex, 05-15-2006 06:06:14
You are on the right lines I think, I have never had the two side by side in front of me, but I would think it is length as some of the others for the older tractors vary like that too. So lets hope you have no problem. You know that the adjustment for the spring is JUST no end play don't you. That may save an email later....lol.....John
