TO-20 TO-35 Input Shaft Seals
Kirk in MI
05-02-2006 06:33:47
I have a TO-20 & 2 TO-35's that are leaking hydraulic oil from the transmission input shafts. The TO-35's are both 2 stage clutches. Does anyone know what the National or CR seal part numbers are for these?
John (UK)
05-02-2006 10:42:33
 Re: TO-20 TO-35 Input Shaft Seals in reply to Kirk in MI, 05-02-2006 06:33:47
Sparex do one for this part # S42395/ MF part # 195523M1, they give the dimensions as 1-1/2" x 2-1/4". if you want to order a Sparex part, order from your local tractor dealer.
Crem
05-02-2006 18:52:19
 Re: TO-20 TO-35 Input Shaft Seals in reply to John (UK), 05-02-2006 10:42:33
Now you have me thinking. I just ordered the same seal for my TO-20 from our local United Auto Supply for $9. I gave them the number 195 760 M1. They gave me a 5872S National/Federal Mogul. I have the seal but have not installed it yet. It measures 2" OD and 1 5/16 ID but the shaft itself might be slightly larger to fit tight in the seal. I think that it is interesting that this tractor ran for 55 years on the original seal and it is not leaking bad, but I want to fix it.
