TO-30 Transmission Shaft
K E Siladi
05-01-2006 17:21:59
Does anyone know if the clutch shaft coming out of the transmission will leak / spill fluid if it is removed? I know it will if I remove the PTO shaft in the back, but what about the front transmission shaft? I figure while the tractor is split for the engine rebuild, I would replace the seal and gasket at this time. Thanks for replying.
John (UK)
05-02-2006 10:46:33
 Re: TO-30 Transmission Shaft in reply to K E Siladi, 05-01-2006 17:21:59
Pretty sure it is above the oil level, but to check...the oil should be no higher in the transmission than the bottom screw that holds one of the round inspection covers on the side below the seat.
