carb problems....advice needed
George in MI
04-30-2006 11:43:01
I am having a problem with my T0-20. It started to miss and quit when at idle. The idle mixture adjustment screw now has no affect on the engine. It will run, but only if the choke is on or the engine is running very fast and probably getting all gas out of the power jet.
I took it apart and tried to clean it out, blow out the low speed passage etc. No improvement.
Any ideas how to clean one of these carbs? I suspect there is a blockage (dirt) in the passage that feeds gas for the idle jet. But I don't see how to clean this. Any ideas? Can you buy a replacement carb?
Thanks
Sodbuster
05-01-2006 11:27:50
 Re: carb problems....advice needed in reply to George in MI, 04-30-2006 11:43:01
Can't offer much more advice than the other guys has already given. You may want to try disconnecting your air pipe from the breather to the carb. Put your hand or something similiar, over the inlet opening to the carb. If it chokes down, you have carb problems, if it keeps running after you have shut off all the air then, you have a big time air leak between carb and valves. Good luck!
gshadel
05-01-2006 07:27:24
Don't sound like a carb problem to me... sounds like an ignition problem. Your engine will run a bit better with weak ignition by pulling the choke because a rich mixture fires easier than a leaner mix. You doubt? Why do we have to pull the choke to start the engine in the first place... richer mixture fires easier.
You can fiddle with the carb if you want. I'd recommend checking out your ignition. Pull a plug and check your spark, you should have a zappy blue spark. A weak yellow spark is no good and will cause EXACTLY the problem you describe.
Check points, condenser, and electical connections to coil, and distributor to make sure they are shiny clean.
George
Jerry/MT
04-30-2006 18:52:55
I think gerard is right, you have a leak downstream of the carb metering system that's leaning the mixture out. That's why it takes choke to make it run. Check the connect flange gasket between the carb and the intake manifold and the intake manifold gasket where it mates to the head. If you have a propane torch, get the engine started and running and take an UNLIT propane torch and with the propane on, CAREFULLY "spray the propane near the above mentioned areas. If the engine speeds up, that's the spot where the leak is at.
If your carb is really dirty, don't blow air through it because you are liable to just lodge it in more firmly. Get some carb cleaner in the spray can and back blow the cleaner through the passages. Or better yet, get a gallon of the real soaking type carb cleaner, and a carb kit and rebuild the carb. But don't do any of this until you sort the leak air leak in the intake system out first.
gerard
04-30-2006 14:21:41
Sounds to me you have a substantial air leak somewhere between carb & valves. These carbs may be crude, but are pretty reliable. We"ve had our TE20 since new (1947) and the carb"s yet to play up.
George in MI
04-30-2006 17:48:38
 air leak maybe...but where? in reply to gerard, 04-30-2006 14:21:41
It does indeed sound like an air leak, but where could this be? Recall this started to happen during normal operation of the tractor, not after I had done any work on it.
The carb was tight to the manifold when I did take it off and, the intake manifold nuts are very tight, and I don't see any cracks in the manifold (but can't see it all of course).
I did wonder about the seals around the lever that operates the throttle butterfly valve...but other than that, I don't know where the leak could be.
ron tepoel
04-30-2006 13:39:39
this carb was fixed many times before, and likely damaged by somebody sometime. It needs to be remanufactured to exact specs in every way.
Also remember new gas is not the same as the original gas, so some adjustment is needed.
Bob Weeks
04-30-2006 12:31:59
I had a TO20 for 30 years. Just gave it to my son. I think it would be fair to say that the Marvel Schlebler carbs are a pain. I had several problems which had similar symptoms to yours. 1. It could be a sticking float valve. Mine used to stick open part of the time and closed part of the time. Carb rebuilds seemed to help some of the time but not for long. 2.I sometimes found some rubberized tank liner plugging the line into the sediment bowl. You can remove the small 1/4 in. plug in the side of the sediment bowl and blow back up into the tank to unplug things. I say this with caution because there is a danger of ingesting gasoline if you aren't careful. This procedure will only be necesary if there is not a good flow of gas from the line at the carb. 3. My TO35 recently would only run at an idle and miss and sputter whenever I opened the throttle. I tried a number of things with the carb including a complete cleaning and readjustment. I finally replaced the condencer in the ignition and it now runs fine. The condencer was nearly new so I didn't suspect it. 4. search the forum by typing in "carburetor". There are numerous discussions about carb. problems. I've learned alot from them
George in MI
04-30-2006 12:55:30
 Re: carb problems....advice needed in reply to Bob Weeks, 04-30-2006 12:31:59
I really don't suspect an electrical problem because it will run at high speed when warm...it just won't run at low speed.
When I start it, it runs for 5 seconds or so, then quits. If you keep the choke on it, will run but as soon as the choke is going off, it quits. This is unlike its usual behaviour, it used to require choke to start but would run almost immediately without the choke unless really cold.
I just took the carb off again, took out all jets and I could squirt gas through all the passages and get it to shoot out ok. It looks like the passges are clear. Even the tiny holes in the idle mixture screw are completely open.
I am stumped....any other ideas???
RustyAL
04-30-2006 18:48:05
 Re: carb problems....advice needed in reply to George in MI, 04-30-2006 12:55:30
There is a small hole that is drilled from the top of the bottom housing to the bottom of the power jet passage. The hole is small and gets smaller. The only way to be sure it is clear is running a small wire through the hole. But before tearing into the carburetor you should pull your plugs. Make sure you have a good snappy spark on each plug. Carburetor problems are ussually the opposite of your problem. The tractor idles fine but starves for fuel at high speed.
