Last question about TO-20 lights
Phil Leithold
04-21-2006 20:44:33
Are original 8N head lights the same as the lights that TO-20's had? Still looking for some good used head lights for my 1948 TO-20
phil(WA)
04-22-2006 08:53:08
 Re: Last question about TO-20 lights in reply to Phil Leithold, 04-21-2006 20:44:33
Ford lights are NOT the same as Ferguson lights. In the beginning, 2N/9N lights were made by C.M.
Hall and used relectors and bulbs in the lights later going to sealed beams. Ferguson lights were made by C.M. Hall also but always sealed beams and the bezels are different between Ford and Ferguson which is the easy way to tell which is which. Ford has always used the clamp type bezel with a single screw or bolt on the bottom of clamp to tighten. Ferguson bezels are held on with two screws visible from the front. So, you should be able to tell at a glance what you have. The 8n lights were a little smaller than the 2n/9n/Ferguson also.
Good luck.
Phil9WA)
Tom H.
04-22-2006 05:00:21
The original headlights were made by C.M. Hall and you would be lucky to find some decent ones. Later model Fords used the Tract-O-lights. They are very similiar in shape and style. New repros of those go for about $130 a pair. I don't know what the lights in the Sparex catalog are going to be going for.
So, if you just want a set light that look okay but not original go with the ford ones.
Good luck and have fun with it.
Joe (IN)
04-22-2006 04:55:11
Yes.
