h s carb to 30
craig gardner
04-19-2006 18:17:11
rebuilt the carb tractor starts up dies starts dies took off farmer went over it put on samething does run on liitle either help
John (UK)
04-20-2006 04:25:11
 Re: h s carb to 30 in reply to craig gardner, 04-19-2006 18:17:11
Have you checked the flow through the carb. remove the plug in the bottom and let the fuel run into a container for 10 mins or so to see if the flow is continuously good. Have you checked the fuel filter in the elbow in the fuel line where it attaches to the carb.
Mike Mohrhauser
04-19-2006 19:57:44
Craig,
Have you checked the float level. My MF-35 was doing about the same thing before I checked and readjusted the float.The fuel level should be about 1/4" down from the gasket.
Mike M.
