T030 Rear end
Joe Alms
04-19-2006 17:03:41
Trying to find what rear axle houseing I have on a TO30 Backhoe. Has casting # MHF 182 189 M1
Below Left side inspection cover. Bought one from another TO30 bolts to trans. but axle bells won't fit.
John (UK)
04-20-2006 04:43:48
 Re: T030 Rear end in reply to Joe Alms, 04-19-2006 17:03:41
there are two centre axle housing on these tractors but they will both attach to the rear of the gearbox. The later one has more studs around the bottom where the trumpet housing attaches.On the early type the studs are equally spaced around the Trumpet. The diffs are different and the axle-shafts too. the early one has 16 splines into the diff and the later ones have 19 splines. The TO30 should have the later heavier type fitted from new. It seems like you have the centre axle housing from a TO20 or a TEA20
