TO-30 Hyd/rear end question
MFrame
04-19-2006 06:19:57
We have a TO-30. the dipstick below the seat on the right side has yellow looking oil on it when you check it. I presume there is water in the system. The question is: Is this Hydraulics or Rear End or both and what kind of and how much oil do we need to change this oil.
Thanks
John (UK)
04-19-2006 13:18:21
 Re: TO-30 Hyd/rear end question in reply to MFrame, 04-19-2006 06:19:57
It takes 24 US quarts to fill it. no more no less through the filler plug alongside the gear lever on top of the gearbox cover.
Jeff-oh
04-19-2006 07:50:43
MFrame
04-19-2006 12:18:53
 Re: TO-30 Hyd/rear end question in reply to Jeff-oh, 04-19-2006 07:50:43
Thanks so much for the information. What would we do without the internet and experts like you willing to share your vast knowledge.
Thanks again.
Jim in OH
04-19-2006 07:27:36
Muuuucccchhh info in the archives! search for hydraulic oil GL1 flush etc. Jeff OH has a good description of a good flushing procedure (maybe he will repost or search archives.) In a nut shell, there are three plugs/compartments to drain, side covers to access for flush, good time to fix that leaking PTO seal, one fill hole, need 6 US gallons of oil if completely drained, GL1 90 (or 80) is the only oil specifically recommended (and is still available from many sources including NAPA part numbers [5gal]65-205 and [1gal]65-201) but substitutions using multigrade motor oil in the range 10w30, 10w40, 20w40, 20w50 have been recommended by some with various pros and cons. Do not use the more modern hydraulic/gear oils as they contain EP additives that can contribute to corrosion of the copper containing materials all ready in your system. Get back with any questions... Jim
