PTO grinds when engaging?
Woody Wilson
04-18-2006 10:46:34
When I try to engage the PTO it grinds,is there a
way to make an ajustment?What can be done to fix this..
John (UK)
04-19-2006 13:22:51
 Re: PTO grinds when engaging? in reply to Woody Wilson, 04-18-2006 10:46:34
The PTO clutch most likely needs resetting through the plate under the clutch housing. Have you checked the pedal clearance under the footrest first, it should be 3/8". If this setting is correct then you will have to go underneath and reset it through the panel. I have the Service Info if you need it for that series of clutches. Email me at:-
fergusontractors(at)tiscali.co.uk
and ask me for the Service Manual for the 35 clutches.
Mike Mohrhauser
04-19-2006 05:57:53
Woody,
If you ever get your problem fixed, let me know. I have a MF-35 with the same problem. It's a major undertaking to readajust a used Dual Clutch. You will need some special tools and a Ferguson shop manual.And then I doubt if it will cure the problem entirely. I would suggest to idle the engine, depress the clutch for a few seconds and then firmly engage the lever.
Mike M.
coup
04-18-2006 17:37:11
slow engine down as much as you can..... before easeing it in.
Woody Wilson
04-18-2006 10:58:42
I forgot to mention that it is 1955 Ferguson TO-35
Jeff-oh
04-18-2006 11:53:21
 Re: PTO grinds when engaging? in reply to Woody Wilson, 04-18-2006 10:58:42
If you are engaging the clutch pedal all the way to the foot plate and still getting the grinding then your clutch is out of adjustment. Adjustment procedures are covered in the shop manuals.
I have never done a clutch adj. thus, this is all I can offer.
Woody Wilson
04-19-2006 05:34:23
 Re: PTO grinds when engaging? in reply to Jeff-oh, 04-18-2006 11:53:21
Thanks for the replies,I will have to order a manual..
