ANother weird gas tank issue....
Doug AL
04-17-2006 19:17:40
I removed the tank from the TO-20 today and was suprised to hear a very heavy rattle (other than the sandy sound of rust flakes) I thought at first maybe someone had dropped a wrench or some tool in the tank at some point--maybe a magnet? But after peering in there as well as possible it looks like a large peice of steel--flat and bigger than either the fuel inlet or outlet that was welded inside at assembly has rusted loose from its moorings inside and is banging around. What is the geography of the tank innard in stock form? Is there a plate or anything welded inside as a splashguard or something that could have come loose? Thanks DOUG
marlowe
04-18-2006 18:00:05
 Re: ANother weird gas tank issue.... in reply to Doug AL, 04-17-2006 19:17:40
it's the baffle they like to brake off JUST leave it it will not hurt a thing i have 5 to-20s and three are in the botton of the tank and been that way for years no real safe way to remove so why do it ?
Doug AL
04-18-2006 05:22:21
SOunds like a baffle of some sort to me too. I guess I'll have to cut it open and remove it in order to line the tank. Although I have a friend who fabs/welds real well and was thinking of having him try to reproduce the identical tank in a heavier aluminum for me. Thanks DOUG
Mansel SoCal
04-18-2006 00:35:51
Sounds like you found a baffle that rusted loose. Most car gas tanks have them inside the tank to keep the gas from sloshing all to one side while making turns and such. When you consider the weight - about 8 pounds per gallon - times 20 or more gallons (in a car), that's alot of weight to be thrown around, making the car harder to handle while manuvering.
Just my 2 cents worth...
Mansel SoCal
Jeff-oh
04-18-2006 05:37:11
 Not to be too technical... in reply to Mansel SoCal, 04-18-2006 00:35:51
The standard weight for fuel (gasoline) is 6lb/ gallon or .763 kg/L water is ... 1kg/liter or 7.86 lb/gal. Thus we use 8lbs/gal as the standard for water.
FYI
gerard
04-18-2006 11:54:10
 Re: Not to be too technical... in reply to Jeff-oh, 04-18-2006 05:37:11
or 10 lbs / gall using the Imperial gallon
Jeff-oh
04-19-2006 07:41:32
 Re: Not to be too technical... in reply to gerard, 04-18-2006 11:54:10
Grin.... LOL
Jim in OH
04-18-2006 06:47:58
I have heard of "heavy water" (D2O, 1.1 kg/liter) before but not your "lighter water"... :-) Don't know what is in your water to make it so light, but most water is about 8.33 lbs/gallon... Link WATER PROPERTIES HERE. Jim
Mansel SoCal
04-18-2006 09:03:51
 Re: Not to be too technical... in reply to Jim in OH, 04-18-2006 06:47:58
Alright...
I figured I would get called on quoting the weight of gas when I knew it was somewhat lighter. I just wanted to make the point that you've got some weight to consider moving around in that tank, thus the baffle(s). Not really a problem even in a car unless you drive the way I did 30 years ago! Thanks for the clairification & enlightenment, guys.
Mansel "Still learning" SoCal
Jeff-oh
04-18-2006 11:50:42
 Re: Not to be too technical... in reply to Mansel SoCal, 04-18-2006 09:03:51
Your point is well made. Did not intent to be to be nit picky.
Thanks for your input.
Jeff-oh
04-18-2006 08:58:13
Math error. I was using a diet Pepsi can for a conversion factor... 12 fl oz. (355ml).
1 kg/liter * 2.2lb/kg* 1 liter/ 1000ml *355ml/12 fl oz. *128 fl oz/gallon. = 8.33lb/gal.
I miss-read the can as 375ml = 12 oz.
Jeff
To30 Jim
04-17-2006 20:37:26
Doug, I had the same thing on my TO30. I cut tank open to find a plate identical stamping etc. to the end of the tank. A baffle or reinfocment. I removed it clean inside of tank,with wire brush, air etc. and got a very, very good welder to weld back the access hole I cut . Then used tank sealer on inside of tank. Cheaper than a new one. Jim
