Evan MacDonald
09-19-2000 08:54:34
I went to start my tractor last Friday, it cranked over about 4 times, and was just about to start(engine is worn out...), but the starter locked up hard, and I had to pull the tractor backwards in high gear to get it unlocked, now all it'll do is turn the engine over a bit and lock up again(not as bad though.) If I pull the plugs out, it'll crank it over, but, it doesn't sound healthy, it's turning slow and grinding a little bit, almost as if the starter isn't engaging right, but the starter is getting hot, so something is holding it back from turning. I can spin the engine over by hand if I put a little tension on the fan belt and turn the fan, so there's nothing wrong with the engine, and there shouldn't be anything wrong with the starter, I just had it rebuilt and converted to a 4 feild 12v setup, and I've only used it 6 times since I got it back, and it works fine if I take it off of the tractor. And to make matters worse, my loader is after sinking to the ground making the tractor immobile. Anyone got any ideas?? Evan MacDonald 55 Ferguson TO 35 S/N 140963 Wagner WF3 Loader
