Sherman input shaft too tight after seal change
Darren in TN
04-13-2006 19:08:33
Howdy, all.
I changed out the seal in my Sherman"s input housing since I had it apart anyway. The new seal went in easily and the shaft fits in it perfectly, but when I went to put the housing back on the Sherman it won"t bolt down all the way. It feels to me like I have 1/8" or so of space between the input housing and the Sherman and with only very light torque the shaft binds. Do I need to press the shaft"s bearing down further into the housing? I thought I had it pressed fully home, but maybe not. Is there anything else in there that can cause this sort of binding?
Thanks,
Darren
Darren in TN
04-13-2006 19:41:32
 Re: Sherman input shaft too tight after seal chang in reply to Darren in TN, 04-13-2006 19:08:33
Well, I went out and gave it one more try. The shaft's bearing wasn't pressed far enough into the shaft housing. I got it pressed the rest of the way in and it went on with no problems.
