tea20 and brushhogging
holcombwa
04-09-2006 21:07:11
Ok, have a tea20 at the back of our place in same shed our John Deere 4 ft. brush hog overwinters. My usual brushogging tractor is in barn at front of the place. In April, there's 20 acres of swamp between the two. Don't usually hog this early, but need to clean some pasture land up so grass has a chance. Sooo.... I'm going to fire up the fergie tommorrow and try brushogging with it out back. Remember reading you let the hog ride on the back wheel, but how do you keep the front end at the correct height again? Can't remember if you do it with the chains on the arms or what. Also, our hog has a couple quarter inch thick steel straps from the top link to the top three point mount position on the tractor to allow some give in the hog. Seems like I remember reading somewhere here that on the ferguson you have to have a solid top link for the hydralics or something similar. If I'm going to be doing something dangerous by using the top link attached to the mount with those straps instead of solid, let me know. On our old Case, just set the hydralics at the height needed and go ahead and hog. But seems like remember there was more to it than that with the fergie. Thanks in advance for your help.
Frank (Virginia)
04-10-2006 21:53:08
 Re: tea20 and brushhogging in reply to holcombwa, 04-09-2006 21:07:11
I am really thinking about getting those chains that hang down from the front edge of the hog. Last fall I was mowing and a rock was thrown forward. It hit the dash and then smashed into my left knee cap. The rock was the size of a baseball.Man that hurt!
To add insult to injury the rock then fell and lodged between the clutch pedal and running board. I had to use the key to cut it off as I couldn't push in the clutch.
Gene Stevens
04-10-2006 04:29:46
This is how I was told to set-up a "Brush Hog" from a expert on this board and it has worked very well for me and others. I do not remember the mans name and what I have here is quoted.
Set-up - I have sold and serviced hogs for years and see this all the time. PLEASE don"t take this wrong but it"s a real common mistake that they are not being mounted right. I know what your thinking how hard is it to put a hog on a tractor and go cut some grass�but�your hog has a tail wheel right? Your tractor has 2 lower lift arms right? Set your hog on a 4x4 so it is level lower your tail wheel so it"s on the ground. Now put your tractor on but �DON"T� hook up the PTO. With tractor running put the 3pt control lever in the middle of the range and turn your top link so it will get longer and you will feel your 3pt. raise just a little and the stop but when you make the top link long it will raise a little more that because the control piston under the set is being pushed in and that makes you 3pt. lift until the pressure is released. With a little fine tuning and a little setting of the tail wheel up or down for the height of cut you want your hog will cut at the height you want. If you have ANY questions call me I will help you set it right 1-920-446-3296 your hog should not be hanging on the tractor when you�re cutting but riding on the tail wheel and the 3pt. at a set height and that is controlled by your top link. Good luck and if you need help call
John (UK)
04-10-2006 04:24:52
What you read about the Hog and the Ferguson was something that our Friend Marlowe wrote some time ago, he sells and services Hogs so he knows a thing or two as you can imagine. You do need a solid but adjustable top link for this otherwise the tractor cant control the height at the front of the Hog. PTO speed of 545rpm is at 1500 engine revs which is 3/4 throttle. Make sure that the radiator is clean and keep it clean. Wash it out with a medium pressure hose until you can see through it using a flashlight at the back of it before you do this job and it wont overheat, make sure that the radiator cap or hoses do not leak, just look for rusty tell tale marks, if there are leaks it will boil sooner than it should do. Change the oil and filter before you start all this work and you will know that it is in the best possible condition to do it. This is what Marlowe wrote:-
Posted by marlowe on June 23, 2004 at 16:01:09 from (209.103.204.81): In Reply to: position control...chains?? posted by mr chapp on June 23, 2004 at 06:16:49:
dear mister chapp. i have sold and serviced hogs for years and see this all the time. PLEASE don"t take this wrong but it"s a real common mistake that they are not beening mounted right.i know what your thinking how hard is it to put a hog on a tractor and go cut some grass? but!! your hog has a tail wheel right? your tractor has 2 lower lift arms right? set your hog on a 4x4 so it is level lower your tail wheel so it"s on the ground. now put your tractor on but[[[[ DON"T]]] hook up the PTO with tractor running put the 3pt. control lever in the middle of the range and turn your top link so it will get longer and you will feel you 3pt. raise just a little and the stop but when you make the top link long it will raise a little more that because the control piston under the set is being pushed in and that makes you 3pt. lift untill the pressure is released.with a little fine tuning and a little setting of the tail wheel up or down for the height of cut you want your hog will cut at the height you want. if you have ANY questions call me i will help you set it right 1-920-446-3296 your hog should not be hanging on the tractor when your cutting but rideing on the tail wheel and the 3pt. at a set height and that is controlled by your top link. good luck and if you need help call. ***********************
Doing it this way and not using chains to control the height, the Hog will follow the ground better, with chains, if the nose of the tractor goes down the Hog will lift up and if the nose of the tractor goes up it will scalp.
Gene Stevens
04-10-2006 04:31:53
 Re: tea20 and brushhogging in reply to John (UK), 04-10-2006 04:24:52
Sorry John, we must have been looking at the same time! Gene
John (UK)
04-10-2006 08:05:44
 Re: tea20 and brushhogging in reply to Gene Stevens, 04-10-2006 04:31:53
No Problem Gene, we never know who is reading these replies do we....lol
steveormary
04-09-2006 21:44:48
holcom
Your Ferguson does not have position control so you use down limiter chains to hold the hog off the ground. You will also need an ORC for the pto. This allows you to stop tractor and not have the hog push you into your wifes new Toyota. You will need a solid top link to keep the hog from comming up and hitting you if you hit a stump or rock or something like that.
Set engine speed at about 2/3rds.throttle. This willgive you close to the propper pto speed. You can also order the Zane Thang,a device that will give you position control.
Be careful and play safe. steveormary
