TO-20 drawbar
lincoln ferguso
04-06-2006 20:12:30
any opinions on installing a swinging drawbar on TO-20, as opposed to one in yhe lift arms. thinking bout getting one but not sure. thanks a bunch.
John (UK)
04-07-2006 13:13:38
 Re: TO-20 drawbar in reply to lincoln ferguson, 04-06-2006 20:12:30
It's as Jeff says, depends on what you want to use it for, any heavy work you need the swinging drawbar, if it is just general work not too heavy you can use the linkage drawbar and there is a kit to stop the drawbar turning if you have that problem or it is quite easy to make something up yourself to stop it.
Jeff-oh
04-07-2006 08:13:48
Here are some opinions...
For pulling swinging drawbar is superior. Standard drawbars will roll in the lift arms if using a ball type attachment.
Downside is they may get in the way when using the PTO. However, An OCR or other extender may provide enough clearance.
Jeff
