Placing rubber seal on oil pan after chaning oil.
walter
09-18-2000 17:56:56
please give some reference to this problem . filter is up inside of oil pan.
tom b
09-24-2000 14:35:49
 Re: placing rubber seal on oil pan after chaning oil. in reply to walter, 09-18-2000 17:56:56
The first time I replaced on my TE20, it leaked. Here's what worked for me.
Get out the grease gun or can of grease and put a good coating on both sides of gasket.
Place the gasket on the pan, make sure its outside the ridge on the pan - the grease will hold it in place long enough to get the cover in place. Tighten and check for leaks.
Put in no more than a quart or two of oil to check for leaks.
If it still leaks, the cover might have gotten bent or warped.
Hope it works. Good Luck.
Tom B
Topeka Ks
