Dave- You've got a TO35. I have one too (a '56) and the decals also say Ferguson 35 (not to35). To make matters more confusing, I think they really are Massey-Harris-Fergusons - at least that's what some of the castings say. But if you call it a TO35 when getting parts, you'll get the right ones. Didn't you post on this before you bought it? Glad to hear it was a live PTO/dual clutch. My PTO lever also grinds a little when I put it in, but not major & I can do it when the engine is running. The dual clutch can be adjusted from underneath (take off the inspection cover). I think there's a bunch of bolts you set clearances on, similar to setting value lash. The MF factory owner's manual doesn't give instructions for this, I just checked. You're probably right about just trying to break the PTO clutch loose first. Try a big rotary cutter? Great tractors. I had an 8N before & the 35, particulary with livePTO/hyd, is a lot more useful. I used a 11 hole drawbar across the 3PH points for 2 years with the 8N with no problems. The first time I used it with the TO35, I put a nice kink in it. Guess they pull/lift considerably harder. a nice kink in it - guess t
