New hydraulic pump
Peter St. Croix
03-26-2006 09:32:25
Hi there
I just finish complete restoration of a 1958 MHF50 tractor. I could not overhaul the hydraulic pump. So I put in a brand new pump by the book. But when I did my first lift of anything. The pump started making a loud knocking sound on every lift and jerking on its way up. It did manage to lift my snow blower. But knocking a lot on the way up like it was banging on the side of the trans casing. I took the side inspection cover off and did a test lift actuating the pump valve only and it still knocks. Is the pump defective? I just installed it . Can anyone help me out. Thanks
John (UK)
03-26-2006 11:46:38
 Re: New hydraulic pump in reply to Peter St. Croix, 03-26-2006 09:32:25
Have you got the locating dowels (pegs) or (pins) fitted to hold the Pump in place or have they broken off the little plate that is fastened to the outside of the housing (oval plate held on with two nuts) when you remove one plate it should have a peg or pin attached to it that locates in the Pump Body to stop it moving, one either side.
