Rear axle seal
Clyde,ns
03-24-2006 17:03:32
Is there a replacement seal for the rear axle that can be installed from the outside?Someone told me about one that maybe has a grease fitting??It's for a 1952 TEA 20
Clyde,ns
03-25-2006 18:05:59
 Re: Rear axle seal in reply to Clyde,ns, 03-24-2006 17:03:32
Thanks for your reply.That sounds like the product i need.The service manual talked about removing a retaining sleeve and bearing which may be trouble.Thanks again for your help. Clyde from Nova Scotia,Canada
John (UK)
03-27-2006 09:00:03
 Re: Rear axle seal in reply to Clyde,ns, 03-25-2006 18:05:59
That "sleeve" they mention is normally called a "collar" and this is shrunk onto the axle-shaft to hold the bearing and hub in position. To get it off it needs drilling and slitting and then the bearing and hub needs to be pulled off with a Puller capable of something like 25 - 30 tons pressure. So you can see why they use these "Sure Seals". The axle shafts are ok to repair if you have the kit to do it with.
John (UK)
03-25-2006 07:52:12
I think you must mean the "Sure Seal" this you can fit to the early axle-shafts (16 spline)there is no need to strip the bearing and collar off the Axle-shaft to fit this, but you do have to remove the Axle-shaft from the tractor. The grease fitting was used on the later axle on TE series tractors after serial number 325,001 (1953) these have 19 splines. An extra seal was fitted to this axle-shaft bearing housing and they fitted the grease nipple as there would no longer be any oil to lubricate the bearing. You can get the "Sure Seals" from SPAREX under part # S61512, they are quite inexpensive. This site also supplies them, look in the TO20 parts pages.
"Sparex" parts are available from most good tractor dealers and they will get them to order for you.
