throttle lever moves back
hank n tx
03-22-2006 16:32:12
my throttle lever wont stay put whenever i go past about a third of the way. when i increase the speed the throttle will go back to about 1/3 throttle. i have to hold the lever by hand. ive tried shimming up behind the linkage plate but it seems that if may be that the governor is the problem. any thoughts and solutions will be appreciated.
thanks hank
gshadel
03-23-2006 05:08:24
 Re: throttle lever moves back in reply to hank n tx, 03-22-2006 16:32:12
Hank
probably need new friction disk between the throttle lever and the dash. They wear out after while. The original was probably cork, replacements are usually rubber. I made new ones out of some rubber gaskets material - works great.
Also check the spring/clamp on the throttle shaft, right behind the dash. Tighten that clamp down on the spring as tight as possible.
George
doodelbug
03-23-2006 05:00:29
i had the same problem. went to the auto supply bought a tachometer and installed it . seems the throttle was staying in the right place . guess i should have turned up my hearing aid so i could tell the rpm's better, lol.
steveormary
03-22-2006 20:26:50
I think it is the nature of the beasts. We had a TE-20 and a T0-30 and they both did that. Mabe Dad had them setup that way so it would be harder for us kids to run them hard.
I never did get the throtle to stay where I set it.
steveormary
Mike Mohrhauser
03-22-2006 19:04:41
Is the compensator spring and linkage intact?
gerard
03-22-2006 16:43:30
Adjust or replace the friction pad (infront of your right knee when seated on tractor).
