TO20 Transmission Question
Joe (IN)
03-21-2006 22:23:29
I was getting ready to put the Sherman back in my TO20 tonight and figured I'd better look at the mainshaft pilot bearing before I put her together. As I was turning it and inspecting the rollers, the dang thing came right off in my hand! Isn't that supposed to be a press fit on to the end of the mainshaft? The way I'm reading the shop manual, the mainshaft has to be driven into the bearing by force during assembly. If so I'm thinking I may have to replace the mainshaft and the bearing. After the old bearing has been spinning on it, I doubt a new bearing would stay put either. Please enlighten me!
souNdguy
03-23-2006 08:33:30
 Re: TO20 Transmission Question in reply to Joe (IN), 03-21-2006 22:23:29
Mic the shaft OD, and see if you can find some specs.. might be a realy worn beairng on a shaft that is otherwise 'in tolerance'.
Soundguy
Joe (IN)
03-22-2006 16:10:20
 Anybody? in reply to Joe (IN), 03-21-2006 22:23:29
Nobody knows if the mainshaft pilot bearing is supposed to be a press fit or a slip fit? Need to know whether or not I need a mainshaft!
Duner Wi
03-23-2006 13:52:30
 Re: Anybody? in reply to Joe (IN), 03-22-2006 16:10:20
I don"t know if pilot bearing as you call it is a press fit. However if you think it is to loose a new bearing might help. Not all bearings are exactly the same. If you like the old bearing maybe you could punch mark the main shaft . If it to hard to punch mark and the bearing is not so loose it wobbles then I would mount it using Lock tite Stud and Bearing mount. If I did punch mark the shaft I would use Lock tite on it also. A new shaft might be difficult to locate. I have had shafts built up with a spray weld process at the machine shop. If you do lock tite it make sure the bearing is fully in the direction it will be when bolted together. Good Luck!
