TRACTOR BINDING UP WHEN CLUTCH LET OUT
COWBOY ROY
03-19-2006 08:50:47
Hello,
Have been pulling stumps with my Ferguson, and just had a problem. Heard a clunk, and now the tractor will start and run, in or out of gear with clutch in, but when I let the clutch out the engine binds, and stalls. Drivetrain locks up on release of clutch. Hear a clunk just ahead of transmission, but don't know if related. HELP! Please... Thanks so much! Roy
John (UK)
03-19-2006 10:22:04
 Re: TRACTOR BINDING UP WHEN CLUTCH LET OUT in reply to COWBOY ROY, 03-19-2006 08:50:47
It could be that the Gear lever has come out of the selectors, occasionally it can happen and yet still be able to use the gear lever to start it. Remove the two nuts at the bottom of the gear lever and check that all three selectors are in a straight line, you may find one is out of line, if this is the case, lever it back into line with the others. If they are in line then something serious has happened in the gearbox, maybe a broken selector. Instead of pulling fence posts out, have you tried using the hydraulics to do it, a chain wrapped around the linkage drawbar works wonders....and it doesn't damage your tractor.
Mike Mohrhauser
03-19-2006 10:05:49
Roy,
With the 1st symptom, I would guess that it may be stuck in two gears. Can you move the gear shift lever? If you can then I am guessing that you might have other transmission problems. You will probably have to remove the transmission cover to get a better look.
Let us know what you find.
Mike M.
