hydraulics
J HOHLER
03-12-2006 17:32:54
I recently rebuilt the pump on my 51 to20.Is it normal for the top caps on the valve chambers to seep a little bit?? I dont want to tighten the bolts to tight in fear of cracking the chambers. I already made a 130.00$ mistake by cranking down one bolt and cracking a chamber thinking that was my initial leak down problem which turned out to be the damn relief valve. Spring is just around the corner and i have 10 acres to maintain,so any insight would be appreciated.
John (UK)
03-13-2006 05:55:00
 Re: hydraulics in reply to J HOHLER, 03-12-2006 17:32:54
There should be no leakage from the top caps on your Hydraulic Pump. You should torque down the caps to 60 - 65 lbs ft. Has your Pump got the washers fitted between the plugs and the valve springs in the top of the side chambers, if not this will be a contributing factor to the leak. In the UK tractors they fitted a rubber cap part 2273. Your problem of leak down would not be the relief valve itself it is more likely to be the check valve on the end of the relief valve, the part attached with the light spring, this keeps the pressure from off the pump itself and does require changing occasionally, the relief valve can cause this problem but you notice a big difference in lifting capacity first, it just wont lift as much. With the check valve leaking the lifting performance is ok but it leaks down when you stop the pump.
J HOHLER
03-13-2006 17:18:16
 Re: hydraulics in reply to John (UK), 03-13-2006 05:55:00
Thanks for the input John, I"m going to start from the begining. About 6 months ago i deciced to rebuild the lift cover. I replaced the rocker shaft bushings and honed the lift cylinder. I then had the lift piston machined for a nylon wearband and a high pressure t-seal thus eliminating the three rings. I then flushed out the belly of the tractor and reinstalled lift cover, leaving the pump alone. Threw on the bucket to test her out.BOY!! worked great for about 30mins, i then hit the clutch and the bucket came crashing down. I then pulled the side covers off to see valve chambers leaking. I pulled The valve chamber caps and washers to clean up and reinstall. Well they continued to leak, so i kept on tightening until the leak actually got worse. I cracked the damn thing.I then dropped the pump, bought a new valve chamber and cleaned up the remaining parts.
I then reinstalled the pump and now the lift is real jerky and weak when i raise it. I noticed that both valve chamber plugs on both sides were seeping, and being a little gunshy i didnt crank them down super tight. Refusing to believe that was my problem i then removed the relief/check valve while the pump was still installed in tractor. I cleaned it off and i was able to blow through it.I thought to myself "what an idiot" that was probably my first intial problem after the lift cover rebuild. I am going to order a new valve and torque the two bolts to 65FT.lbs. and hope for the best. If the caps continue to leak i"ll have the machine shop at my work make 4 new plugs to fit the chambers better and use 2-series orings to seal on the ID"S. THANKS FOR YOUR TIME.
J HOHLER
03-14-2006 11:42:50
 Re: hydraulics in reply to J HOHLER, 03-13-2006 17:18:16
Thanks for the suggestions John,I"m going to order a new valve tonight. I"ll keep you updated on the results. Thanks, J HOHLER
John (UK)
03-14-2006 07:12:03
I must say that I find that the three piston rings do last a lot longer than the neoprene type. The hydraulics "jerking" like that means that it is not running on all four cylinders of the pump, you have a leak on one maybe two through the side chamber to Pump Body gasket or "O" rings whichever your type is, you are going to have to drop the pump out again but try to find the leak first as this will save you a lot of time and uncertainty, you can never be sure that you have cured the problem unless you find the actual leak point. A pump on a bench is hopeless to repair unless you find the leak first as there is no pressure to leak and it would be pure luck if you did manage to cure it. Unusual for those caps to leak like that, are you sure that the parts are reassembled in correct order or are all the parts in there. The safety valve doesn't collect anything in there usually, the pressure is too high, it would just blow it out, the check valve is the one to look at first if the hydraulics are dropping and there are no leaks in the other usual places, that little valve supports all the pressure that is in the system to stop it going back to the Pump itself, they do get worn and allow the oil to gradually leak through, you can of course get exactly the same problem if the safety valve is worn too, it will leak out of there just the same. The easiest way if there is any doubt about these valves is to fit a new safety valve as this will replace the check valve at the same time, you would be surprised how often that cures the fault.
