Electronic tach
Griz
03-11-2006 07:27:41
I installed a tach yesterday on my To-20. It's one of those electronic wrap around a spark plug wire kind of things. Problem is, when comparing revs to my idle tach/dwell meter. The electronic tach reads twice as much at idle. The tach/dwell meter reads between 400 and 450 rpms, the electronic reads just shy of 800 rpms. At 2000 rpms they are within 100 rpms of each other. Almost dead on at 1500 rpms.
The tractor has a new cap and plugwires, recently replaced for a dead cylinder problem. That was a horror story involving compression checks, sparkplug and wire swaps. Had plugwires with no terinals held in with rtv and a cap with an open between the inside and outside terminals. She is banging on all four now.
The tach is made by ENM. It can be programmed to sense two or one pluse per revolution or one pulse in two revs. The maintenance meter can be set for any number of hours you want. Seems to be able to do quite a bit. Had a tach from Northern Tools. It worked for a couple of minutes then read any where from 400 to 30000 rpms at idle. Did the same thing on my truck. Sent it back and got this one.
I set it for one pulse per two revs and wrapped it around the number four wire. Read about 1200 revs. Tried it on the coil wire sensing two pulses per rev. I figured the higher the sampling the more accurate the tach should be. It reads 800 revs now. Any one out there especially the electronic guys knows what the problem might be?
gshadel
03-13-2006 10:04:03
 Re: Electronic tach in reply to Griz, 03-11-2006 07:27:41
Griz
I'm not familiar with your particular tach. so what I'm about to say may, or may not help.
I installed an electronic tach from N. Tools a couple years ago. Fortunately, mine has been working fine, sorry to hear about your misfortune. Attaching the sense wire to the coil wire does not improve accuracy. Those meters are built to work on a 1 piston fire senario, and you program the number of engine revs per fire, so it will work on about any engine, regardless the # of cylinders. By hooking-up to the coil wire, your getting 4 times too many input signals to the tach.
I think you need to connect your sense wire to a plug wire. I can't recall now how many revs correspond to one fire, maybe 2 or 4 revs. Either way, you will know when you have it right when programming it because it is easy to tell if your engine is running at ~400 RPM, ~800 RPM, or ~200 RPM. at idle.
I wrapped some black electrical tape around the sense wire on the plug wire. It matched the plug wire so it looks nice, and keeps the sense wire tight against the plug wire so I get consistent readings. The instructions on mine also called for a specific number of loops around the plug wire when wrapping the sense wire. Don't know if yours is the same or different.
Hope this helps
George
