Governor
Griz
03-08-2006 05:07:13
I"ve been getting my TO20 in shape for the summer. My problem is with the governor. It won"t hold the throttle setting when I move the lever past about 2/3 of the movement. It backs off to about 1500 rpm"s. That"s not altogether bad since that is where I want to mow at. Is this normal?
At 2/3 movement the governor spring begins to tighten up. When I let go of the throttle the spring slowly pulls the throttle back. My manual doesn"t mention this hapening. If I were to adjust this out the settings would at the limits of adjusting. The adjustments shouln"t be so extreme. I did replace the cork friction disc with no help.
Griz
03-08-2006 13:49:47
 Re: Governor in reply to Griz, 03-08-2006 05:07:13
I figured the friction disc was bad after I put some visegrips on the shaft and compressed the spring as far as it would go and tightened the clamp back up. I replaced the cork pad. Still did it. Thought maybe the cork friction pad spring was torqueing up. It wasn't. Then I noticed the vertical springarm was compressing. I looked at the linkage settings and didn't notice any extreme settings. It sure will take serious adjustments to get it to hold high rpm's. I figure it must be the nature of the beast.
Maybe it could be your Dad's old tractor.
John (UK)
03-08-2006 12:20:23
The problem with the throttle creeping back is the friction disc at the back of the air cleaner, slacken the clamp off and compress the spring then tighten it up.Is this spring heavy enough, has it been changed for a lighter one. Make sure that the friction disc is not too hard or it will not grip.and it should be of some rubber material anything that will grip. then you may need to set the governor itself if it doesn't work properly, I have the information for doing that and if you need it email me at:-
fergusontractors(at)tiscali.co.uk and ask me for it. The PTO speed of the tractor(545rpm) is at 1500 engine rpm.
gshadel
03-08-2006 09:47:24
Griz,
Sounds like you either need to look through and adjust your gov. and throttle linkages to the carb., or just need to tighten-up the throttle lever on the dash.
The throttle lever has a rubber or cork friction disk between the lever and the dash, and a spring loaded clamp deal on the backside of the dash to hold the throttle lever tight against the dash. If the clamp loosens up, or the friction material wears out, throttle slips. Check that.
I had similar problem after rebuilding my engine. The process to work through and adjust all the linkages between the carb, throttle and gov. is fairly time consuming step by step. If you don't do them in order, won't work right. Take a look at your manual on adjusting the linkages and work through them. Between that and the lever, that should fix you up.
I ended-up making new friction disks for behind the throttle out of rubber gasket material, worked pretty good.
1500 RPMs aint bad anyway. I don't like running my engine beyond that anyway, sounds like the engine is really screaming beyond that anyway. That's my normal bushhog speed anyway.
George
Mike Mohrhauser
03-08-2006 09:26:10
So far I have bought three Ferguson's and they have all had the same problem. I have found that all of them had the compensator spring on the throttle linkage missing. Once you get that in place it should take care of the throttle creeping problem.
Mike M.
Steveormary
03-08-2006 09:14:59
Griz;
I think it is an inherit charectorisik of the darn thing. Ours would do that almost from the day we bought it new. Of course,I always suspected Dad had some thing to do with it so us kids wouldnt run the tractor too hard and fast.
I think 1500 engine rpm gives you close to 540 pto rpm. Good luck and have fun.
steveormary
