TE20 tach
LT Beck
03-07-2006 05:12:43
Can the TE20 be fitted with a mechanical tach? If not are there modifications one can make to adapt the T030 or Ford 8N/9N mechanical systems?
Thanks, Tony
to30
03-08-2006 18:08:46
 Re: TE20 tach in reply to LT Beck, 03-07-2006 05:12:43
My TO30 has a tack it has a gear adaptor on the back of the generator like the TO35 and is cable driven.I bought it for $30.00 at a tractor show a real find at any pricein my book.
John (UK)
03-08-2006 12:40:42
The genuine Ferguson Tacho was driven by a pulley running on the back of the fan belt at the generator (well one model was like this) I think the one the guys are telling you about, the digital one is far neater and works perfectly and I personally would go for that one.
to/te
03-07-2006 15:04:55
Tony you can put a Ferguson tack on if you can find one ,my dad had a TE20 with the tack you will need to replace the generator to a Delco because the tack drives off the back of it and the Lucus will not work ,The set up is about like the To35.
Jerry/MT
03-07-2006 10:00:06
You can also put an electronic tach on the tractor that gets it's signal from the coil. That's what I did. I clamped it to the steering column with a hose clamp.
gshadel
03-07-2006 08:57:51
The TE20, and all the TO's and N's can be fitted with a digital tachometer that works darn good. I have made posts in the past on these, I installed one a couple years ago on mine and have been quite happy with it. Below is a link to Northern Tools where I got mine, there are other sources as well. I just glued the display right to the dash. It has a sensing wire that wraps around the spark plug wire, and a built-in battery, so it does not matter if you are running 6V or 12V.
