TO-30
Jack Schlosser
09-05-2000 10:04:02
My neighbor has a TO-30 which he has just reassembled (bought in pieces). When the engine runs, there is a lot of noise (not a knock)which sounds like valve train noise, but tightening up the valve adjustment does not help. Any ideas on what we might look for? Thanks!
dennis
09-06-2000 10:00:08
 Re: TO-30 in reply to Jack Schlosser, 09-05-2000 10:04:02
If it sounds like valve train, are you getting oil on the rocker arms? The rocker shaft must be installed with the proper lineup of the oil holes in the supports with those in the shaft and oil must be getting up to them thru the oil supply holes in the block and head. Oil should be running all over while the engine is running.
fred
09-06-2000 09:59:28
Make sure the valve train is being oiled. The oil path is from the head up thru the back rocker arm holding bracket then horizontal along the hollow rocker arm shaft. Good luck.
