PTO / ???? on sparex catolog
Willy / 30-OD
02-23-2006 18:35:57
I have a problem with my pto shaft and seal assembly matching the sparex cat. I have a 195763m1 seal. it measures 5/8 thick ( not dia. ) the one I took out is 7/8 thick! I have 2 snap rings , ( the same size & dia. ) one to hold in the seal and one hold the bearing. My pto shaft is 1 3/16 with a 1 5/8 slug over it to set in the seal ( no wonder it leaked ) I just got this to-30 and in the process of getting it ready for paint.there was alot of oil and dirt at the pto shaft outlet. has anyone else come across this same situation??? or does anyone know way I don't match the catolog diagrams???
Willy / 30- OD
02-25-2006 12:21:44
 Re: PTO / ???? on sparex catolog in reply to Willy / 30-OD, 02-23-2006 18:35:57
John , if you need more info on the pto shaft . I'll be back home on mon. are there any numbers for the replacement kit you know of? also have you ever seen a slug type bushing that sets inside the seal??? Thanks for the reply!!!
John (UK)
02-26-2006 11:38:55
 Re: PTO / ???? on sparex catolog in reply to Willy / 30- OD, 02-25-2006 12:21:44
Just check the size of the pto shaft that sticks out the back end of the tractor and that will tell you what it is. If it is 1-3/8" 6 splines it is a Sparex S280 conversion kit and the parts are listed in the catalogue, if you have difficulties sorting them out, email me at fergusontracors(at)tiscali.co.uk and tell me what you need and I will sort the numbers for you, I have most of the lists. Re the slug type bushing, not sure what you mean by that but I am sure that you can explain, maybe we call it something else...John
John (UK)
02-26-2006 11:42:25
 Re: PTO / ???? on sparex catolog in reply to John (UK), 02-26-2006 11:38:55
I misspelled the email address, it should read:-fergusontractors(at)tiscali.co.uk
and the spell-check missed it too.
John (UK)
02-24-2006 10:36:32
Has your tractor been fitted with the 1-3/8" 6 spline shaft instead of the original 1-1/8" 6 splined shaft. If it has you will have to use the alternative seals/bearings etc. from the replacement PTO shaft kit.
