sandblasting a complete tractor
chris sweetland
02-23-2006 14:44:51
i know they say not to sand blast an engine that is all together but what about the trans and rear end? i was just wondering because my to-20 is a working tractor and i cant take it out of service for more than a couple of days
gerard
02-23-2006 16:20:02
 Re: sandblasting a complete tractor in reply to chris sweetland, 02-23-2006 14:44:51
If you've only got a couple of days, forget it. It'll take best part of a day just to prepare -(wheels / mudguards off etc) and all holes blocked off & all other areas where grit may get in properly protected. Then it's gritblast. prime, undercoat & gloss - with a day to dry between each coat. Need a week at least. As for grit blasting an engine - when its together is the ONLY way to do it, otherwise there's a danger of damaging important surfaces. Same as trans - block all orifices & protect all areas (like where crank exits block) so grit doesn't get past oil seals.
