Burch Plow???
Bob H 1640
02-19-2006 23:16:12
I recieved a burch plow s/n 40168. it is a 5 point 64 inches wide. I tried to mount it on my TO20 but no luck. I've never used this type of plow before, I thought it was a tye of subsoiler?? Any clues to its worth and if it will fit the TO20
Bob H 1640
02-20-2006 08:29:48
 Re: Burch Plow??? in reply to Bob H 1640, 02-19-2006 23:16:12
J2, The one that I have has the teeth on a single solid 2" sq. bar. Three of the teeth are mounted on 3" X2" cast arms and the teeth are interchangeable, the outside teeth are on steel bars 3" wide by 1/2" thick with the teeth bolted between. It is all very heavyduty built and hard to pick up and move about.
J2
02-20-2006 06:29:04
third party image
Look something like this, only a little smaller? It is a "ripper" or chisel plow. Five feet wide is probably too big for a 20. If it won't fit, then it probably has a CAT 2 or CAT 3 hitch on it which suggests that it is made for a bigger tractor anyway.
J2
02-20-2006 06:37:19
 Re: Burch Plow??? in reply to J2, 02-20-2006 06:29:04
I should have added that the one pictured had an dealer asking price of $395.. Yours is smaller, so I am guessing in the range $200-$250.
