tea 20
Gibbo
02-17-2006 20:31:39
I have a yellow coloured 1952 Tea 20 with no three point linkage and a three speed gear box.
I believe it was used on the wharves at outer harbor Adelaide SA as a tow motor.
does anyone know whether in fact this would be a four speed gearbox with a gear removed or perhaps a gate put in. It does not have the raised number 4 on the cover. I would like to return to four speed.
John (UK)
02-18-2006 11:27:40
 Re: tea 20 in reply to Gibbo, 02-17-2006 20:31:39
There is no TEA shown as being made with a 3 speed gearbox, are you sure that you haven't got a Ford 9N which looks like a Ferguson, but it only has three speeds and a side valve engine, the Ferguson has four speeds and an OHV engine.
cdmn
02-18-2006 17:06:23
 Re: tea 20 in reply to John (UK), 02-18-2006 11:27:40
Does it start with the gear lever moved to "S"?
Is the gear case cover cast in one piece with the steering column? Otherwise, it should be easy to take the cover off and look at the gear set-up.
