JB Weld fix crack?
chuck130
02-15-2006 12:13:58
Aluminum thermostat housing on my 54 TEA 20 cracked right where the temp sensor goes. If I grind it out and 'fill' with something like JB Weld, will it hold the pressure of the cooling system?
Thanks
dutches
02-19-2006 18:41:02
 Re: JB Weld fix crack? in reply to chuck130, 02-15-2006 12:13:58
I patched the block on a GMC 2 ton truck with j b weld. The crack was 10 inches long and at least 1/2 inch wide. It's been almost a year and it's not leaking yet.
Bill Clark
02-18-2006 00:18:05
Have a buddy that welded a cracked motor block with JB Weld, drove it for years never gave him a problem Be sure to clean the area well and scuff it up before you apply.
BCTO30
phil(WA)
02-17-2006 15:26:23
Fixed my radiator and has been 4 yrs. I had no choice at the time and as Mike says what do you have to lose.
Phil(WA)
Sodbuster
02-16-2006 12:23:47
Nosirree!!!!!
Mike Mohrhauser
02-16-2006 05:49:52
What's the most you have to lose by trying?
chuck130
02-16-2006 04:42:35
Appreciate the short answers. Thanks
gerard
02-15-2006 12:41:24
Get a good welder to TIG weld it. Will be fine.
randy
02-15-2006 12:32:19
Nope
