help...how to get fenders off a TO-20??
George in MI
02-11-2006 08:22:55
I have a TO-20 with TO-35 fenders. I wanted to get them off to paint them.
1. I could not budge the big bolts on the axle from the bottom, even with a big socket/extension wrench. Of course, I can't undo the nuts from on top of the axle because I can only get a small wrench in there and they won't budge either.
2.. I thought I could just take the fender off the brace that holds it. However the fender skin is partially (some place with nuts/bolts) attached with something that looks like rivets. They are rounded on both sides...so how can you get those off??
3. I also thought I might remove the wheel so I could get better access to the top bolts. How hard is it to remove those wheels? The whole wheel/tire combo looks very heavy to me so I wondered how to get it safely off and back on again.
So how can I make one of these plans work....or is there a better way?
BobinKY
02-13-2006 18:15:05
 Re: help...how to get fenders off a TO-20?? in reply to George in MI, 02-11-2006 08:22:55
I finally got mine off by soaking with PB blaster over a couple of days and betting my four hundred pound nephew that he could not get them off. It worked. You could blow them off with a torch (smoking wrench) as they are easy to replace with standard bolts from tractor supply or any hardware store. You will probably want to replace them anyway when you see how much the center of the bolt has deteriorated over time.
Aikidoforever
02-12-2006 09:20:14
Hi there,
I got the fender off by using a torch and penetrating oil on the bottom nuts and using a socket. But be warned that even once those nuts are off, you will still need to get the bolts off from the top, so the wheel had to come off (for me). Torch and penetrating oil and lots of elbow grease. I found taking the nuts off the wheel a real task. Torch and penetrating oil didn't seem to get them to budge, but I was using a crescent wrench. Bad move, cause' the angle of the wheel and the wrench wouldn't allow a good, tight grip. So I got myself a break bar with a long handle and the right socket. That worked. Impact tools would have helped I think... Good luck. Ivan
SandyB@TN
02-11-2006 09:11:56
George,
First, there are 3 rivets holding the fender to the fender bracket. I wouldn't cut these. You need to remove the fender and bracket as a unit. Some air tools, impact tool specifically, would be real friendly in this situation. Without this, I would hose the nuts down with PB Blaster or Liquid Wrench. Let it sit and try again in an hour or so. You can warm the nuts up with Oxy-Acetylene. That will normally break them loose.
To take the wheel off is not too bad. Jack the tractor up just enough to take the weight off the lug nuts. Lean the top of the tire toward you, not much, and work it off the lugs. You need a place to lean the tire/wheel for storage. If you lay it down and it is fluid filled, you'll have the dickens to get it back up. Weighs about 400 pounds when fluid filled.
Jim in oH
02-11-2006 09:08:37
You are doing it right, but you will need a bigger wrench and maybe a torch. I used an air impact wrench after soaking them several times with penetrating oil, then heating the nuts to red. They get rusted on pretty good.
2. I thought I could just take the fender off the brace that holds it. However the fender skin is partially (some place with nuts/bolts) attached with something that looks like rivets. They are rounded on both sides...so how can you get those off??
They ARE rivets and you will have to grind them off� They are expanded tightly into the holes when they were put in, so it is a bit difficult. You can get replacement rivets (from fastener places on line) that look similar, but again are a pain to put back on. I intend to thread the rivet shaft and use acorn nuts on the back side. Some have used carriage bolts to simulate the rivet or just use hex head like the rest if you don�t care about originality.
Wheel lug nuts may be rusted on and may need impact wrench and heat (mine did). The wheel/tire is heavy especially if filled (500 lbs?). (Mine are.) After loosening them, keep one nut on to keep the wheel from falling.. jack just until the wheel is loose.. now you can maneuver/twist/turn the wheel (keeping it vertical) and roll it to a wall or something to lean against. Don�t let it lean. If it is filled, and it gets away from you�get out of the way�It will take more than one person to get it up� I was able to get mine rolled to the wall by myself (my 5� wife was there to call 911 if something happened) I recommend that two people handle this one.. escpecilly if it is your first time.
You are on the right track� just 50 years of rust in your way� Jim in OH
