TEF-20 Hydraulics
Jack Machin
08-30-2000 13:38:55
I have a TEf-20, which is about 46yrs old, but, the hydraulics arent very good, the links either go up, or they go down,and even worse, if you leave the PTO out of gear, and the mower is on, then you can see the lower links dropping rapidly, whilst hearing,thud!thud!thud! can anyone please help
rod
08-31-2000 06:56:59
 Re: TEF-20 Hydraulics in reply to Jack Machin, 08-30-2000 13:38:55
You have to take it apart and look for wear in the pump also try taking off the side cover and looking to see if the piston is leaking fluid down when in operation or just take it out and rebuild it, be careful.
regards
rod
rod
Jack Machin
08-31-2000 12:31:49
 Re: Re: TEF-20 Hydraulics in reply to rod, 08-31-2000 06:56:59
I am only 14, soon to be 15, I would take it out myself, I like mechanics, but I have no nowledge of hydraulic pumps, so, do you think that a garage cold fix the problem,
thanks alot
Jack
Jack Machin
08-31-2000 12:38:54
 Re: Re: Re: TEF-20 Hydraulics in reply to Jack Machin, 08-31-2000 12:31:49
I think that the problem might be du to wear on the CONTROL VALVE, I think that the oil is just flowing straight past it!
This is only an idea though!
rod
08-31-2000 14:52:46
 Re: Re: Re: Re: TEF-20 Hydraulics in reply to Jack Machin, 08-31-2000 12:38:54
It would have to be a tractor dealer Ford or Massey Ferguson to fix the pump or you can take it apart yourself by getting a service manual. Keep everything clean put it on a large flat surface and go at it slowly if you want. You could email Stevens ag parts at www.stevensagparts.com or call 1 800 333 9143 and get a free catalog it has a nice pic of the hyd pump disassembled. If it was leaking by the control valve you can see that when you have the side cover off I think might have to drain some fluid out first. Also you may want to visit or join my Yahoo Ferguson Club it is free and over 200 club members to help with advice. If you are not sure of what you are doing leave it alone.
regards
rod
rod
08-31-2000 15:02:16
 Re: Re: Re: Re: Re: TEF-20 Hydraulics in reply to rod, 08-31-2000 14:52:46
Just remembered if you go to www.samstractor.com and look in the parts for massey ferguson hyd pump you will see an online parts drawing of the pump. regards
rod
Jack Machin
09-01-2000 11:30:49
 Re: Re: Re: Re: Re: Re: TEF-20 Hydraulics in reply to rod, 08-31-2000 15:02:16
Cheers Rod, thanks for the help!
