loader arms
dan from bright
02-02-2006 19:56:40
the hydraulic arms on my ferguson front end loader are leaking fluid badly , is this something i can repair or should i take them somewhere,the little ring keeps poping out....
gerard
02-06-2006 14:12:04
 Re: loader arms in reply to dan from brighton, 02-02-2006 19:56:40
I see you're getting no replies, so I'll jump in.
I don't know your ability, so can't advise whether you can do it yourself. Some rams can be simple, others a nightmare, depending on fixing. You say 'the little ring keeps popping out'. I presume you mean the retaining circlip / ring? If that's the case, the ram body will probably need to be stripped, put in a lathe big enough for it to pass up the spindle, and the groove re-machined. Sounds like a fully equipped workshop needed.
