Adding hydrolics to a TO-30
Just 1 More
02-01-2006 10:27:03
How can I add hydraulics to a TO-30 to run hydraulic activated equipment attached to the 3PT hitch? I need to run a Lime spreader behind my TO-30 but the dang thing is hydraulicly activated.
I know there are fittings on the gear case.. i"m sure I tap in to those somehow, but whatelse do I need to do? UK John... can you help me on this one?
Just 1 More
02-04-2006 16:57:51
 Re: Adding hydrolics to a TO-30 in reply to Just 1 More, 02-01-2006 10:27:03
no one knows???
Duner Wi
02-05-2006 06:36:30
 Re: Adding hydrolics to a TO-30 in reply to Just 1 More, 02-04-2006 16:57:51
How much volume of oil do you need? Gallons per minute to run your motor? You can tie your draw bar down and tap in to side of transmission. threads are maybe 1/2"by 20 TPI. Some have pipe threads. Be careful here. Now if you need more than about 3gallons a minuute to supply your motor you will need either a pto driven pump or an engine driven pump. This might get you started.
