TO-30 Governor problem
dfitch
01-30-2006 08:05:04
I have just installed a new Novi (ball bearing) type governor and cannot get any governing action after adjustment. The installation instructions from Tisco said to install with the arrow and tab to the top of the engine. My Ferguson manual said to install with the tab at the 8 o'clock position. Which is correct?
Also in my manual for replacing the governor there is a caution to check the 5/32 inch diameter vent opening in the camshaft. I did not do this and am wondering if that might be my problem. There is a 2nd reference to this vent in the camshaft section of my manual saying if this vent is obstructed it is impossible to obtain satisfactory operation of the governor. From the diagram in the manual it looks like this vent would be about where the governor cup shaft ends in the camshaft. Has anyone had any experience with this vent and is it necessary to remove the camshaft to check it?
