To30 throttle
scott
07-25-1999 10:19:19
have just pruchased a to30. having a problem with the throttle lever. wants to run wide open all the time. i assume that there is an adjustment that is needed in the linkage somewhere. do not know much about this however. previous onwer was using a couple of springs to hold back the lever. i prefer not to do this. thanks
Randy
07-30-1999 14:18:48
 Re: to30 throttle in reply to scott, 07-25-1999 10:19:19
When I got my to30 about a year ago, the same thing was wrong with mine. The owner before me had removed one of the springs from the throttle lever near the governor. A shop manual shows you where the springs should go. Sticking out of the side of the governor is a small screw with a nut on it that you can adjust as well. The manual will tell you how to properly adjust the throttle linkage and governor. Once I did all of that, mine ran like a top.
Paul
07-25-1999 18:46:09
Scott - I strongly suggest you get a shop manual for this tractor. You could have several things that need adjusting: governor, linkage, idle, etc. You can order one from this site at "Manuals." Good luck.
Paul
