TED20 Knocks at idle
DonDK
01-28-2006 09:35:39
I have just finished a lengthy rebuild of my TED20 Petrol/Paraffin engine, and now it knocks at idle. I have replaced the pistons, liners, big/main bearings, timing chain, oil pump ignition points, skimmed the head etc. The oil pressure is a steady 30 - 40psi. However when I let the engine idle slowly eg approx 400 rpm, it makes a frequent - knock knock knock pause..... .knock sound. It disappears when i open the throttle slightly, doesn`t knock when i rev it up or drive up a slope to make the engine work, and is most noticeable when the engine is properly warmed up. It is a relatively gentle sound at the moment and by using a listening stick it seems to come from either the lower engine or the front but is difficult to pin point. What could this be? I thought it would be as good as new. I would be very grateful for any help you could give me.
Bob Weeks
02-08-2006 20:33:06
 Re: TED20 Knocks at idle in reply to DonDK, 01-28-2006 09:35:39
I have a TO20 with a gas continental engine that has a knock similar to what you describe. It appeared after I did an engine overhaul. That was in 1972. It has had this gentle knock all this time and I have used it that way for over 30 years. I was told by an old tractor mechanic that it is end play in the cam shaft. Apparently, it isn't critical because I have used this tractor alot mowing grass, brush hogging, grading, plowing etc.
Crem
01-29-2006 14:01:40
Do you have the standard engine in your Ferguson. If so, this may not help you, but a number of years ago my TO-20 continental engine also had a knock in the front at idle. I found out that the front cam bearing had too much clearance. Actually the cam runs right in the block without an installed bearing. This engine had a lot of hours on it. Anyway with the rocker arm cover removed, I found out that when running the engine at an idle, I could make the noise go away if I pushed down and put pressure on the front rockers in the right place. This seemed to keep the camshaft from klunking up and down on each revolution.
gerard
01-28-2006 14:59:15
This type of noise can be a real pain to pin down. Good news is, its unlikely to be major (first thought was wrong size BE shells, but reading rest of our post - no.) So what could it be? Piston slap - maybe. SE bush (I always replace these on a rebuild - many don"t) but unlikely - that would be a gentler tapping. Sure you got all the BE caps mated with their respective rods & torqued up? Is your crankshaft endfloat within spec? Only other suggestion is either camshaft endfloat or a dodgy tappet (camfollower).
rustyj14
01-28-2006 11:46:20
Could the flywheel be loose? I'm not familiar with that tractor, but something might be loose inside. A loose flywheel will make that noise. Or, if there is a balancer, or the pulley on the front of the crankshaft, it might be loose!
Aaron Ford
01-30-2006 16:20:41
 Re: TED20 Knocks at idle in reply to rustyj14, 01-28-2006 11:46:20
I would pull the pan, at any rate.... See what you can do to recreate the noise.
