gaskets for hydraulic pump and top cover ??
John Gerrits
01-27-2006 04:05:10
My tractor is a 1953 FergusonTEA, 20-85,which I am rebuilding. The original gaskets for the hydraul pump base and lift cover to rear housing were of a heavy,fiberous material (rather like head gasket material). I assume this was because the oil pressure from the hydraulic pump flows through a hole in these gaskets to the lift cylinder. The replacement gaskets I have obtained are of a paper-like material; will they be able to stand the hydraulic pressure?
gerard
01-28-2006 15:15:50
 Re: gaskets for hydraulic pump and top cover ?? in reply to John Gerrits, 01-27-2006 04:05:10
Coming in here because no-one's answering your post. I'd hoped John UK or similar would have replied. I know the tractors but not the gasket issue. Only comment I'd make is, provided any clearances etc are not compromised, the only purpose of a thick gasket is to cater for irregularities in surface flatness. A thin gasket is actually less likely to blow under pressure than a thin one. In essence, doubling gasket thickness doubles the strain it takes.
My 135 has a little gasket protrusion near the hydraulic tapping and when I asked my MF dealer for a gasket, he told me to scrape it off and use silicon, as they weren't available or needed.
Hope this helps. In absence of better inforemation, I'd use the thin gasket with a thin smear of something like hylomar.
Mike G, in NB, Canada
01-30-2006 15:33:52
 Re: gaskets for hydraulic pump and top cover ?? in reply to gerard, 01-28-2006 15:15:50
I agree that the gasket would be better off thinner.
(John G. is my dad. How cool is that? :-)
-mike
