TO35 block cracked
Max P
01-24-2006 13:12:41
Just took the head off my TO35 gas and there is a tiny crack between three of the four cylinders. What is the cheapest way to fix this and it's been running like this so does it need to be fixed and has anybody tried things like jb weld? Thanks for any help.
Big Dean
01-25-2006 17:32:21
 Re: TO35 block cracked in reply to Max P, 01-24-2006 13:12:41
The Head gasket will usually seal off the cracks from the cylinders on the top end of the block it is the cracks between the cylinders on the bottom end that you have to worry about
Max P
01-25-2006 13:49:31
I have been told that sometimes it is better off to leave the cracks alone if there isn't any water in the oil which there ian't?
