No Spark - TO20
Hatman21
01-23-2006 13:23:12
UGH....I own a TO20.
No Sparkplug spark... New battery, coil, starter motor switch, plugs, points & condesner.
Here is what I got so far:
1. Check all wiring. Looks good
2. Fuel delievery - working
3. Battery charged
4. Checked sparkplug wires- looks good
however, when I installed the points, which are the second new set, I noticed that the gap was like 1/4 inch and when the post turned the gap only closed to 3/16. And I did not see a spark.
If I ground it with a screw driver, spark. The set of points of replacemtn points, I took a pair of plyers and mashed the points together, and still no sparks, but then again, I had no gap either.
And ideas, comments or suggestions?!
Thanks
dfitch
01-24-2006 04:44:37
 Re: No Spark - TO20 in reply to Hatman21, 01-23-2006 13:23:12
Not sure but it doesn't sound like you are using the correct procedure to adjust the points. You don't bend the points to adjust them. Rotate the shaft until any one of the 4 lobes comes up and makes contact with points. Loosen the outside screw and then rotate the adjusting screw in the center of the points to adjust the gap then tighten the outside screw.
Jerry/MT
01-23-2006 22:13:58
Point gap 0.022 inches.
hatman21
01-23-2006 17:50:29
Anybody have any idea what the gap for the points should be??
Thanks!
gerard
01-23-2006 15:20:20
Get those points sorted out. Check electric continuity to coil.
