possible hydraulic solution on a to-20
chris sweetland
01-23-2006 12:36:11
i had a thought today while going through all my hydraulic pumps since the one in my to-20 is toast and the housing cracked so a rebuild wont work. untill i find a replacement can i mount a front pump run lines into the right hand cover plate and tap into the controls for the 3 point? will this work or is it a fun dream
John (UK)
01-24-2006 13:33:46
 Re: possible hydraulic solution on a to-20 in reply to chris sweetland, 01-23-2006 12:36:11
Yes it is possible that it would work, the only thing that would stop you is the position the cracks are in the Pump body as they could let any pressure through. So to be sure say No.
Jerry/MT
01-24-2006 08:18:48
I doubt that you can tap an external pump into the lift cover without plugging the output from the original pump. Oherwise the external pump fluid will backflow through the original pump and not pressurize the lift cylinder.
Jim in OH
01-23-2006 13:23:15
 Re: possible hydraulic solution on a to-20-Zane Li in reply to chris sweetland, 01-23-2006 12:36:11
I'd probably go for original (I am a purist) but you could probably put something together yourself from new or used parts that will do what you suggest. If you want new, Zane Sherman sells this complete "live" kit for Ford and Ferguson... calls it the "Live Thang". For more info... See link...
Jeff-oh
01-23-2006 13:06:56
There is one available on e-bay right now. Item 7584107151. sells in six days. There are rebuils available from various companies too.
