oil leak front seal
Dave Matthews
01-20-2006 19:37:51
Thanks guys for help on replacing Pto shaft.
(all done)
I have a problem with oil leak Te 20 when parked on downward slope.
What seal is needed? And can a person with a medium knowledge of tractor repairs do this job himself?
gerard
01-21-2006 05:09:42
 Re: oil leak front seal in reply to Dave Matthews, 01-20-2006 19:37:51
You don"t say which front seal - engine or gearbox, but I"ll presume the latter, as it would be unusual for the engine to leak from the timing cover just on a downslope. Pretty straightforward - split tractor and remove housing containing seal - replace , check clutch if it hasn"t been checked / changed recently, & put back together. Good handyman type of job. Just remember to wedge axle so engine doesn"t tilt when coming off g"box, and don"t force tractor halves back together by using draw-bolts etc - that"ll wrek the clutch driven plate. To split it, either take weight by blocking under engine and pull back end away with a trolly jack under transmission, or block up tranny and put trolly jack under engine & pull that forwards. I"ve always preferred the latter.
