Normal operating temp
Terry Knaus
08-21-2000 21:28:35
just would like to know how hot all your TO20's are running,under a load mine is running between 190 and 200 without a thermostat,outside temp is over 100 degrees,doest apeer to be any water leaks.also my oil presure sending unit seems to be not working,i bought my temp sending unit from local big three auto and was wondering if i could do the same with the oil unit,thanks
Bill Mc
08-23-2000 19:45:26
 Re: normal operating temp in reply to Terry Knaus, 08-21-2000 21:28:35
My TO-20 has no thermostat and runs 135 deg f on a 90 deg f day, working hard!! I installed a new capillary temp gauge (6 foot) bought from quality farm & fleet($20).Oil pressure runs 22 lbs hot at mid rpm.Good luck
Bill Mc
Kristian
08-22-2000 18:59:18
I put a mechanical gauge on my TEA-20 and the temp is running about 115-120. I just got this tractor so I am still getting used to it. I have been told that the thermostat should be located in the radiator hose. (If it's there) Is this the location or is the thermostat in the housing that sits on the engine block? Thanks!
SandyB@TN
08-22-2000 17:21:43
Terry,
Mine runs about the same as yours. Right at 200 degrees. Mine doesn't have a thermostat either. Iv'e checked and the standard thermostat starts opening at 165 degrees and is fully open at 190 degrees, so 190 to 200 degrees sounds about right. I was sweating it for awhile, but I'm about to get used to it. It does make the gas in the tank boil, which is a little disconcerting.
hope this gives you some info you can use.
Sandy
Fred OH
08-21-2000 23:11:41
Terry, mine didn't work either and I took the crescent wrench out of my pocket and tapped on the dash underneath and it started working and still is. It doesn't have a sending unit, just a gage with a metal line connecting it. Any 2" gage should work on it if the threads fit. L8R----Fred
