TO30
JHB
01-13-2006 14:40:07
Is there a good source for Ferguson TO30 parts? I think I may need to replace the flywheel. I think the ring gear is moving off and rubbing on the bell housing. Or is there a solution for repositioning the ring gear and keeping it in place.
Duner Wi
01-13-2006 18:10:54
 Re: TO30 in reply to JHB, 01-13-2006 14:40:07
When my ring gear fell off I installed a new one and to keep it in place I drilled and tapped 6 or 8 evenly spaced holes around the parimeter. I bent the washers under the bolts over the edge of the flywheel to contact the ring gear.Been working fine for many years now.
Jerry/MT
01-13-2006 22:41:31
 Re: TO30 in reply to Duner Wi, 01-13-2006 18:10:54
Clever fix Dunner!
Duner Wi
01-13-2006 18:09:52
Jerry/MT
01-13-2006 16:38:04
If your ring gear is moving back, it's a result of the way the starter engages and the fact that you may have an original style flywheel. I had a similar situation where my ring gear came off and wedged between the flywheel and the bell housing. Ferguson had a design mistake on the original flywheel because they sweated it on from the back side of the fly wheel. Repeated starting would drive the ring gear off. They redesigned the flywheel by addining a small lip on the back edge and sweated the ring gear on fom the front. Some people tried to repair the original flywheels by welding the ring gear on. My original was welded on and all the welds broke out. The flywheel is white cast iron I believe and if you're gonna' weld it, you have to do it right with pre-heating and controlled cooling. I foumd a new style flywheel and replaced my origninal one with it and have had no more problems.
Hope this helps you.
