TO-35 hydraulics
Roger
08-21-2000 06:51:48
Whenever I raise the 3-point implement the whole thing shakes and vibrates all the way up and continues to do so (though not quite as much) when fully raised. As I lower it to the ground, the vibration stops. Anobody have any experience with this problem?
Jack in NB
08-23-2000 06:50:43
 Re: TO-35 hydraulics in reply to Roger, 08-21-2000 06:51:48
Hello, Roger -
Your problem is consistent with a problem in the internal pump.
It's a 4 cylinder pump, with intake and exhaust valves similar to a normal 4 cyl engine, and when one or more valves get worn, the pump misses - with the same impact on output as an engine with one or more plugs misfiring.
Parts are readily available for most models (there are at least two different pumps in the 35's).
