voltage
jason kaemmerli
01-09-2006 18:22:07
i have a 1949 ferguson to20 how do you tell if it is 12 or 6 volt
Mike Mohrhauser
01-09-2006 20:28:57
 Re: voltage in reply to jason kaemmerling, 01-09-2006 18:22:07
Look at the top of the battery. If it has 3 caps for three cells it will be a 6v. If it has two caps for 6 cells it's a 12v. On lead acid batteries it's always 2 volts per cell.
Mike M.
phil(va)
01-09-2006 19:17:58
I"m assuming you just bought the tractor and don"t know the owner and have no one to ask. Some things to check: Put a meter on the battery and see what the voltage is. Look at the generator or alternator; if it is an alternator it almost certainly is 12 volts; if it is a generator it could be either but most likely 6 volts. Look at the coil; it may say 6 or 12 volts on it. Normally 6 volts will be positive ground, so if the battery ground strap is from the positive side of the battery that might be an indication (assuming it has a battery in it). Look at the light bulbs; they may say 6 or 12 volts on them. Hope that helps.
