loader installation
Bruce in BC
01-08-2006 20:40:16
Hi, I have a 1954 Tea 2085 and I have aquired a small loader which I plan to install. The thing is is that I am going to attach a hydraulic pump to the front so when I am on the clutch I will still be able to opperate the loader. Has anyone done this before. I would really like some input.
Ed H.-OH
01-09-2006 17:11:42
 Re: loader installation in reply to Bruce in BC, 01-08-2006 20:40:16
Bruce ,Hello, I have a To35 that i put a wagner loader on with the front pump off the crank pully. I bought a front pully for the z134 engine that was made for this reason. It came with an adapter plate that goes on the pully with bolts mounted in rubber and the shaft that came with it threads in with lefthand thread. I will be glade to email you picks as i have them on file from another discussion if you send a mail and let me know you want them. I run a loader and a backhoe off it and it has worked well for 20 years.
Laurence
01-09-2006 04:32:53
No real reason why you should not mount a hydraulic pump driven straight off the crankshaft. You need to make sure you have the right type of hydraulic system so the pump can freely circulate the oil when power is not required. Or else the pump will soon wear the pressure relief valve out. My bro has a industrial verson of the MF35 which has the FEL and back hoe powered this way. One small detail though, your starter motor will have to work that little bit harder as it will be turning the pump as well. Might be an idea to go to 12volt electrics if you have not already done so.
