governor shaft seal
DWD
01-08-2006 16:30:48
I am replacing shaft seal and bearings on a TO30. How do I remove the pin that holds the shaft?
gerard
01-11-2006 06:32:09
 Re: governor shaft seal in reply to DWD, 01-08-2006 16:30:48
If you turn the shaft to an angle that gives the most clearance for the pin behind, it's just possible to drift it out with a pin punch. It's lightly riveted at the ends.
K. E. Siladi
01-09-2006 17:43:12
Filing is a pain in the you know what. I used a stone in my drill chuck. You can only drive it out about an 1/8 inch at a time and then you have to grind it. Make sure you you clean it real good afterwards to get rid of all the filings. It seems to be an odd size as I found out after - 11/64. I'll either drill out to 3/16 or I might use a metric roll pin I found at work that seems to fit.
John (UK)
01-09-2006 12:28:55
Not easy to do on this engine or the TO20. Service Manual says "file the head off but no further dismantling is possible". I am pretty certain we used to do these without too much trouble, but they are more difficult than the Standard Motors type.
